08-31-2018 07:31 AM
We recently took over a network switch for one of our properties that was managed by a vendor since it was riddled with security holes. The RSA key is 768 bit, if I wanted to make it 2048 or 4096 could I just run the crypto key generate rsa command and have it recreate the key? I am not on site and do not have access to it via the console port so if this will kill ssh I can't do this. If it kills the current session but I can just start a new one with the new key right away that is fine.
Thank you
08-31-2018 08:30 AM - edited 08-31-2018 08:34 AM
Your session should not get disconnect if you create a new SSH key with a different bit size. It may take a few minutes 93-5min) generating the key if you choose 4096. But the session should not drop.
While the key generation is in the process, any new sessions will be refused.
R1#ssh -l cisco 1.1.1.1 Password: R2# R2# R2#conf t Enter configuration commands, one per line. End with CNTL/Z. R2(config)#cry key gen rsa The name for the keys will be: R2.cisco.com Choose the size of the key modulus in the range of 360 to 4096 for your General Purpose Keys. Choosing a key modulus greater than 512 may take a few minutes. How many bits in the modulus [512]: 2048 % Generating 2048 bit RSA keys, keys will be non-exportable... [OK] (elapsed time was 16 seconds) R2(config)# R2(config)#
08-31-2018 12:00 PM
what is the device model ? and what is IOS version running ?
09-01-2018 10:45 AM
This is a good response which shows clearly that generating a new RSA key does not impact the existing SSH session. It clearly addresses the concern expressed in the original post. +5 for this.
Rick
