Runnig TCL script manually?
noel-thompson
We are running a TCL script via a cron job with no issue, every 2 minutes and it working like a bomb.
When i try run the script manually via the event manager run xxx.tcl it say that it is not registered?
When i check the sh event manamger policy registed it says it is?
Any ideas?
Noel
Joe Clarke
You can only run EEM policies manually that are registered using the none event detector.  Take a look at the Testing section of this doc:
https://supportforums.cisco.com/docs/DOC-12757
If you can support multiple events and you register your policy using both the timer and none EDs, then you can run adhoc tests as well.
Hi Guys,
How to write tcl script and kron jobs that will backup the router config every 60 minutes.
CF
You don't need kron or Tcl for this.  You can use the built-in config archive feature of IOS:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtrollbk.html#wp1100253
If you do want to go the scheduled route with EEM, start a new thread for your issue.
mhnedirli
you can do with this
kron occurrence BACKUP_TIME in 30 recurring
policy-list BACKUP_POLICY
kron policy-list BACKUP_POLICY
cli copy run start
