10-27-2005 02:04 AM
When a try to schedule a job in RME i always get a msg back that the time must be in the future, even when set it a few days a head on different times it always come back with the same info screen.
Bundles Installed
Bundle Name Version Install Date
1. LMS 2.5 02 Aug 2005
Products Installed
Showing 1-6 of 6 records
Product Name Version Installed Date
1. CiscoWorks Common Services 3.0.2 17 Aug 2005, 11:32:42 CEST
2. Campus Manager 4.0.2 17 Aug 2005, 13:55:17 CEST
3. CiscoView 6.1.0 02 Aug 2005, 09:42:12 CEST
4. Device Fault Manager 2.0.0 02 Aug 2005, 10:42:28 CEST
5. Integration Utility 1.6.0 02 Aug 2005, 09:42:12 CEST
6. Resource Manager Essentials 4.0.1 17 Aug 2005, 11:48:12 CEST
10-27-2005 03:47 AM
Are you using a non US English locale anywhere?
10-27-2005 04:04 AM
I am in Europe, so the server. What are the correct settings.
10-27-2005 05:49 AM
You have to make sure that you are using US English, else you will get these kinds of issues.
10-28-2005 01:46 AM
Yes oke but where must i set it?
10-28-2005 11:27 AM
I think it's this:
"Control panel" -> "regional options"
Your locale (location)
Select "English(United States)"
http://www.microsoft.com/globaldev/handson/user/2kintlsupp.mspx
Let me know if this fixes the issue
Cheers,
Michel
11-01-2005 11:48 PM
from my point of view this is a BUG because when i choose NOV it will work. Only Oct gives problems.
11-02-2005 04:52 AM
What day in November are you using?
Does it work for November 13 or later (14, 15...)?
11-02-2005 06:29 AM
the first of nov
11-02-2005 06:42 AM
