Schedule will not work
jefvaneijk
Level 2
Level 2
When a try to schedule a job in RME i always get a msg back that the time must be in the future, even when set it a few days a head on different times it always come back with the same info screen.
Bundles Installed
Bundle Name Version Install Date
1. LMS 2.5 02 Aug 2005
Products Installed
Showing 1-6 of 6 records
Product Name Version Installed Date
1. CiscoWorks Common Services 3.0.2 17 Aug 2005, 11:32:42 CEST
2. Campus Manager 4.0.2 17 Aug 2005, 13:55:17 CEST
3. CiscoView 6.1.0 02 Aug 2005, 09:42:12 CEST
4. Device Fault Manager 2.0.0 02 Aug 2005, 10:42:28 CEST
5. Integration Utility 1.6.0 02 Aug 2005, 09:42:12 CEST
6. Resource Manager Essentials 4.0.1 17 Aug 2005, 11:48:12 CEST
9 Replies 9
nhabib
Level 11
Level 11
Are you using a non US English locale anywhere?
I am in Europe, so the server. What are the correct settings.
You have to make sure that you are using US English, else you will get these kinds of issues.
Yes oke but where must i set it?
I think it's this:
"Control panel" -> "regional options"
Your locale (location)
Select "English(United States)"
http://www.microsoft.com/globaldev/handson/user/2kintlsupp.mspx
Let me know if this fixes the issue
Cheers,
Michel
from my point of view this is a BUG because when i choose NOV it will work. Only Oct gives problems.
What day in November are you using?
Does it work for November 13 or later (14, 15...)?
the first of nov
