Secure CRT
Michael Mutua
Hi everyone,
To all engineers who love cisco CLI, what is the possible solution to this below error
Key exchange failed.
No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512
Any possible solution will be appreciated.
kind Regards,
Michael
20 Replies 20
pabloarturo2023
Try to add these MAC to the switch:
ip ssh server algorithm mac hmac-sha2-256
fazalscorner
Just add this command on the switch(9000 series), if you are having an older version of SecureCRT  and it will work .
ip ssh server algorithm mac hmac-sha2-512 hmac-sha1 hmac-sha2-256
This worked on 8200 Router as well. thanks.
Thank you @senthilr for the info. It works nicely.
Regards, LG
*** Please Rate All Helpful Responses ***
Kenn Alcira
Try to run this in the switch
ip ssh server algorith mac hmac-sha2-256
it will add the hash algo in the switch. That works on mine.
Yes, Kenn! It works also for me.
