SFP not connected from one side
polsmurad31763
I have a strange problem , i have connection between 2 switches 9200L and 3750X with SFP GLC-LH-SMD
and on the 9200L side shows Connected and on the other side (3750x) shows Not connected
balaji.bandi
how is these connected direct patch cable ? or you have a provider involved to connect?
GLC-LH-SMD  (what kind of patch cable or cable you using to connect both ?)
post below output  both the side
show run interface gi x/x
show interface gi x/x
suggest try no negotiation should work
BB
5 Replies 5
Mark Elsen
 - Make the connection again, and then check the logs on both platforms ,see if you can find anything useful
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
BB
 no negotiation on both switches worked for me thank you very much
Leo Laohoo
Connected on one side but "not connected" on the other?
I have seen this before.
Test and make sure the entire length is not broken.  The description described is due to one of the fibre pair is broke.
@Leo Laohoo  i agree here, since you getting circuit loop you also see one side UP/UP.
BB
