03-11-2024 11:48 AM
I am "borrowing" this Switch from a friend [though now I think i know why he was so giving] and for the life of me, it will not upgrade the image.
It currently has 1.4.11.5 and I want to upgrade to the latest.. No matter [latest or not] image I try to upgrade to, it errors out with 'General Error' [if i rename it like image.bin] or 'Copy:illegal software format' [if i leave it named from cisco].
Really not sure the reasoning is. I see many different answers and having to downgrade to upgrade etc, but I am already at the higher image than the one I need to downgrade to. Any suggestions?
Oh, and I can not console into it because it literally has a serial port, whereas I only have connectors to the rj45 style console.
Solved! Go to Solution.
03-11-2024 04:06 PM
Hello @TheGoob ,
the latest Firmware Version for the SG500X is 1.4.11.5 and the filename is sx500_fw-14115.ros and should be uploaded to the switch as it is.
Be sure to select File type: Firmware Image from the Administration - File Management - Upgrade/Backup Firmware/Language page.
Here is a link with additional info regarding the firmware upgrade: https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-500-series-stackable-managed-switches/smb3180-upgrade-firmware-via-http-https-on-sx500-series-stackable-sw.html
I don't have a SG500X, but I just upgraded a SF300-24 to the latest firmware 1.4.11.5 without any issues.
Hope this helps.
03-11-2024 04:06 PM
Hello @TheGoob ,
Hope this helps.
03-11-2024 04:50 PM
Finally got it to work. I literally had to reset to factory like 4 times then it finally took it. Geeze I think my house is cursed.
