Show command
maryodriscoll
Level 3
Level 3
I wonder does anyone know this?  Can anybody tell me there is show command available that will display all the commands that are enabled by default.....i.e. a show run will show what commands you have enabled but what about the commands that are already enabled by default e.g. no ip icmp unreachables etc..,
Mary
Michel Hegeraat
Level 11
Level 11
I think it is one of these depeding on the version of the IOS.
show running-config all
show running-config full
Cheers,
Michel
