SNMP check etherchannel interface members
m.hierling
I use snmpwalk to check our switches. My problem is, i want to check wich interfaces are assigned to an etherchannel but i don't find the right oid.
5 Replies 5
bwilmoth
Level 5
Level 5
The OID for the object “interface” is “1.3.6.1.2.1.2”
i checked this oid, but the output don't show me which interface is assigned to an etherchannel (port-channel), or am i blind?
I have found the SNMP to monitor if a port in a EtherChannel fails.
dot3adAggAggregateOrIndividual
http://ipmsupport.solarwinds.com/mibs/IEEE8023-LAG-MIB/item.aspx?id=dot3adAggAggregateOrIndividual
for PAgP I use this OID (pagpGroupIfIndex):
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=pagpGroupIfIndex&translate=Translate&submitValue=SUBMIT
For LACP I'd need to do some research (IEEE8023-LAG-MIB dot3adAggEntry, CISCO-LAG-MIB).
Please let us know which channel-protocol your're using.
Hope that helps
Rolf
For LACP I found two interesting objetcts in IEEE8023-LAG-MIB:
IEEE8023-LAG-MIB::dot3adAggPortSelectedAggID.28 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortSelectedAggID.82 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortAttachedAggID.28 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortAttachedAggID.82 = INTEGER: 337
ifName.28 = Gi2/4
ifName.82 = Gi3/10
ifName.337 = Po1
#show etherchannel 1 summary
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi2/4(P)       Gi3/10(P)
Best regards
Rolf
