04-25-2025 03:18 AM
Hi everyone,
I recently deployed a new Cisco Catalyst C1300 switch and configured SNMP monitoring (SNMPv2c) using PRTG. I’m able to successfully monitor:
However, I’m unable to retrieve data for CPU usage, memory utilization, or temperature sensors. I’ve tried using SNMP walk tools but couldn’t find relevant OIDs returning values for these metrics.
My questions:
Any help would be greatly appreciated. Thanks in advance!
04-25-2025 03:57 AM
- @Yivgeny >...Does the Cisco C1300 series support SNMP monitoring for system health (CPU, memory, temperature)
I doubt it , because these devices are small business oriented, for temperature , you could try
to snmpwalk the CISCO-ENVMON-MIB (https://oidref.com/1.3.6.1.4.1.9.9.13.1.3)
Cisco MIBS these days can be found at : https://github.com/cisco/cisco-mibs
M.
04-25-2025 05:24 AM
Thank you for your answer, it's not working.
Found this article - https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt3636-snmpv3-common-oids-cbs350.pdf
Base on this article can monitor cpu during last munute/second. Looking how to monitor Temperature and memory also.
Any advice ?
04-29-2025 07:18 PM
Is there any solution to this problem? I have the same problem....
08-26-2025 07:58 AM
We had the same problem here. But for now we're using some MIBs related to Cisco Business (CBS350).
Some OIDs:
Memory Temp: .1.3.6.1.4.1.9.6.1.101.83.2.1.1.1.4.68420481
Physical Temp: .1.3.6.1.4.1.9.6.1.101.83.2.1.1.1.4.68420483
Mac Temp: .1.3.6.1.4.1.9.6.1.101.83.2.1.1.1.4.68420482
CPU: 1.3.6.1.4.1.9.6.1.101.1.9.0
Uptime: 1.3.6.1.2.1.1.3.0
Hardware Serial Number: 1.3.6.1.2.1.47.1.1.1.1.11.67109120Yes, the first dot is important for temperature sensors.
We didn't find any OIDs for memory usage.
For interfaces, you can map using the Cisco IOS SNMP Template (sorry we use Zabbix, I don't know how you can use discovery rules in PRTG). But here is the Zabbix discovery rule if its useful
discovery[{#IFOPERSTATUS},1.3.6.1.2.1.2.2.1.8,{#IFADMINSTATUS},1.3.6.1.2.1.2.2.1.7,{#IFALIAS},1.3.6.1.2.1.31.1.1.1.18,{#IFNAME},1.3.6.1.2.1.31.1.1.1.1,{#IFDESCR},1.3.6.1.2.1.2.2.1.2,{#IFTYPE},1.3.6.1.2.1.2.2.1.3]
