SNMP commands to collect info about serial numbers of routers
DmitriyShkurko
Dear experts,
could you please advise on the following issue I have encountered?
Problem:
Need to collect information about routers via SNMP: serial numbers, model names etc.
How I tried to solve it:
I have found the information on the Internet about so-called MIB barnacles to be included in customer view.
These are the ones I had intended to use:
entPhysicalModelName .1.3.6.1.2.1.47.1.1.1.1.11.13
entPhysicalClass .1.3.6.1.2.1.47.1.1.1.1.5
entPhysicalSerialNum .1.3.6.1.2.1.47.1.1.1.1.11
The configuration team in my company applied the commands in a slightly different manner:
snmp-server view clientview entPhysicalEntry.5 included
snmp-server view clientview entPhysicalEntry.11 included
snmp-server view clientview entPhysicalEntry.11.13 included
The applied configuration above didn't work as expected.
Question:
What can be done to correct the issue so that the information would be collected?
Thanks in advance!
balaji.bandi
you can have read only view
snmp-server community bbview  view VIEW RO
Tested using my Linux box with snmpwalk :
# snmpwalk -v2c -c bbview  10.10.10.10 1.3.6.1.4.1.9.5.1.2.19
SNMPv2-SMI::enterprises.9.5.1.2.19.0 = STRING: "XXXXX"
BB
Sergey Lisitsin
DmitriyShkurko,
Try querying this string:
iso.3.6.1.2.1.47.1.1.1.1.2.1
It should return the chassis ID and the serial number.
