SNMP config Problem in Ipswitch WhatsUp Gold v.11 ........
Dipesh Patel
Level 2
Level 2
Dear all,
Pls guide me ;
I want to configure IpSwitch for SNMP discovery - than what to do with all devices and how to conigure in Ipswitch software
I have done :
1. configured one RO snmp community in all the devices.
2. In Software it ask for one snmp enabled GW : ( can i give any device IP with SNMP enabled ? )
3.SNMP community RO in Software also given.
but for discovery it takes 7 hours ...is it ok......????
Other problem is that i have enavbled syslog - and im receiving it but the date shown by software was wrong --- how to correct it ....??? Date in syslog msg comes from device is correct ...
pls help .....
smalkeric
Level 6
Level 6
see these steps for configuring devices for syslog analysis:
To configure message logging on a Cisco IOS device, enter the following commands:
logging on
logging server-ip-address
logging trap informational
To configure message logging on a Cisco Catalyst device, enter the following commands:
set logging server enable
set logging server server-ip-address
set logging server facility server-facility-parameter
set logging server severity server-severity-level
set logging server all 6 default
configuring and accessing whatsup Gold:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_small_network_management_solution/1.0/quick/guide/csnmqsg.html#wp39795
