09-12-2016 06:50 AM
I want to monitoring count of free ip address in dhcp-pool by SNMP.
I can't find the OID.
Object | alDhcpServerStatsActiveLeases |
OID | 1.3.6.1.4.1.3076.2.1.2.37.1.1 |
But it didn't work :( on my router (Cisco 2911 ios 151-4.M)
Solved! Go to Solution.
09-13-2016 03:45 AM
Hi Maxim,
unfortunately , it is Not supported.
CSCdw52563 Provide for a MIB to support DHCP stats
Thanks-
Afroz
***Ratings Encourages Contributors ****
09-13-2016 05:25 AM
unfortunately no :(
Please mark this thread as resolved ,if it answered your query !!
09-13-2016 03:45 AM
Hi Maxim,
Thanks-
Afroz
09-13-2016 03:58 AM
09-13-2016 05:25 AM
unfortunately no :(
09-14-2016 02:03 PM
Hi guys,
Actually, there are other ways to achieve the result:
1- Using CLI
show ip dhcp pool [name]
2- Using DHCP Accounting
For instance using a Radius Accounting server with DHCP Accounting Services feature, it's possible get the DHCP pool details from accounting records.
Igor
