SNMP Help - wrong state for failed fan
Eric Varner
Trying to figureout what I'm doing wrong.  Have a Cisco 2821 router with Fan 3 not rotating.  SNMP setup to trap on fan status, but the state shows to be shutdown and not failed as the router messages would indicate.  The router is at a very remote location and I cannot verify if it's actually turning.  Just going by what's presented when accessing the router.
Anything I can do to change the state so that it triggers alerts on our monitoring system?
PP9-2821#show environment
Main Power Supply is AC
Fan 1 OK
Fan 2 OK
Fan 3 failed
Fan Speed : Normal
System Temperature: 35 Celsius (normal)
Environmental information last updated 00:00:25 ago
PP9-2821#
Dec 22 09:44:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:45:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:45:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:46:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:46:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:47:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:47:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:48:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:48:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:49:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:49:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:50:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:50:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:51:04: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
Dec 22 09:51:34: %ENVMON-3-FAN_FAILED: Fan 3 not rotating
MIB OID: 1.3.6.1.4.1.9.9.13.1.4.1
*ciscoEnvMonFanState = shutdown(4)
Description:
  The current state of the fan being instrumented.
Enumerations:
1 -  normal
2 -  warning
3 -  critical
4 -  shutdown
5 -  notPresent
6 -  notFunctioning
Any/all help would be greatly appreciated.
gfcisco31
Hi mate...
dont you have some options like this ?
R1(config)#snmp-server enable traps envmon fan ?
  shutdown      Enable SNMP environmental monitor shutdown traps
  statuschange  Enable SNMP environmental monitor status change traps
  supply        Enable SNMP environmental monitor supply traps
  temperature   Enable SNMP environmental monitor temperature traps
  voltage       Enable SNMP environmental monitor voltage traps
i think statuschange would help....
let me know
Thx for the info!
I did walk the MIB a bit more and found the envmon+fan+statuschange
Router snmp-server fan status change enabled.
Now I receive this message on the monitoring station:
ciscoEnvMonFanStatusChangeNotif.0
Response packet  contained the error: No Such Name
Still in the troubleshooting stage at the moment.
