SNMP: How to get list of IP addresses and corresponding interface names
Jakub Obetko
i have list of IP addresses of interfaces of router. I need to get the corresponding interface names (e.g. fa0/0) so that i can match them with the list of ip addresses (e.g. i have ip 192.168.1.1 and i need to find out that it is IP of fa0/0). Is there any MIB in SNMP which can be utilized for that purpose?
Thank you very much.
jakub
AFROJ AHMAD
Hi Jakub,
* you can use  IP-MIB object ipAdEntIfIndex (1.3.6.1.2.1.4.20.1.2) to identify IP Address. for a specific interface and its ifIndex.  Again, these interface ifIndices can be translated through ifDescr (1.3.6.1.2.1.2.2.1.2) to map the specific interface description.
Description    "The index value which uniquely identifies the interface to which this entry is applicable. The interface identified by a particular value of this index is the same interface as identified by the same value of the IF-MIB's ifIndex."
For example :
snmpwalk -v2c -c private 10.104.149.18 1.3.6.1.2.1.4.20.1.2    <<=== ipAdEntIfIndex
   IP-MIB::ipAdEntIfIndex.1.1.1.231 = INTEGER: 108
   IP-MIB::ipAdEntIfIndex.2.2.2.1 = INTEGER: 157
   IP-MIB::ipAdEntIfIndex.7.7.7.100 = INTEGER: 107
IP-MIB::ipAdEntIfIndex.10.104.149.18 = INTEGER: 78      ====>> 78 is Management
Interface (Vlan1) ifIndex
   IP-MIB::ipAdEntIfIndex.11.11.1.1 = INTEGER: 91
   IP-MIB::ipAdEntIfIndex.11.11.2.2 = INTEGER: 92
   IP-MIB::ipAdEntIfIndex.11.11.3.3 = INTEGER: 93
   IP-MIB::ipAdEntIfIndex.51.51.51.2 = INTEGER: 100
   IP-MIB::ipAdEntIfIndex.55.55.55.2 = INTEGER: 101
   IP-MIB::ipAdEntIfIndex.61.61.61.1 = INTEGER: 102
   IP-MIB::ipAdEntIfIndex.65.65.65.5 = INTEGER: 103
   IP-MIB::ipAdEntIfIndex.79.161.80.43 = INTEGER: 109
   IP-MIB::ipAdEntIfIndex.99.1.1.1 = INTEGER: 5
   IP-MIB::ipAdEntIfIndex.100.1.1.1 = INTEGER: 160
   IP-MIB::ipAdEntIfIndex.127.0.0.51 = INTEGER: 79
   IP-MIB::ipAdEntIfIndex.192.168.10.1 = INTEGER: 105
* The above result shows the IP addresses associated with different ifindex(es).To check which ifindex is associated with each interface, you can use the ifDescr (1.3.6.1.2.1.2.2.1.2) OID.
   $ snmpwalk -v2c -c private 10.104.149.18 ifDescr
   IF-MIB::ifDescr.1 = STRING: GigabitEthernet1/1
   IF-MIB::ifDescr.2 = STRING: GigabitEthernet1/2
   IF-MIB::ifDescr.77 = STRING: GigabitEthernet9/8
   IF-MIB::ifDescr.78 = STRING: Vlan1      <<===  Management Interface (Vlan1) IfIndex is 78
   IF-MIB::ifDescr.79 = STRING: EOBC0/0
   IF-MIB::ifDescr.80 = STRING: Null0
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Its is very helpful! Thanks...
Glad , it helped you
Thanks-
Afroz
Mado42
This is very helpful! Thank you @AFROJ AHMAD for the great description.
Have anyone tried to append the IP to the Interfaces Table (IF-MIB::ifTable) as a Telegraf configuration?
I am trying to assign IP addresses to the ifIndex tags using Telegraf SNMP Plugin as a data collector. The configuration looks like this one here https://sbcode.net/grafana/cisco-switch-influxdb/.
Now all I want is, to be able to find out which IP Address is assigned to the interface an interface with the ifIndex<X>?
Is this possible?
Kind regards and thanks in advance for your support!
Mado
