SNMP OID of CPU for WS-C4510R+E
HI Everyone,
I have some problem about CPU OID for WS-C4510R+E in VSS mode.
These problem as below:
1\ I want to know the OID vaule of WS-C4510R+E CPU usage.
2\ I have found these value of OID:
Object
avgBusy5
OID
1.3.6.1.4.1.9.2.1.58
Object
cpmCPUTotal5minRev
OID
1.3.6.1.4.1.9.9.109.1.1.1.1.8
but i can get the CPU usage by OID avgBusy5,but the CPU usage is not match the value by "show process cpu"
i cannot get the CPU usage by cpmCPUTotal5minRev.It told me not have this OID.
3\ I want to know the CPU usage that is got by avgBusy5 is a average vaule of two physical CPU,or just only the active device's CPU usage?
4\ the CPU usage circule is 0-100,it's right?
Other info:
software:cat4500e-universal.SPA.03.05.03.E.152-1.E3.bin
Engine:WS-X45-SUP7-E
mode:VSS
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Has anyone done CPU monitoring for catalyst 4510 VSS?
