SNMP OID temperature
duwijakarta
Helo SIR
please help me, I want to add a temperature switch graph to the cacti, how do I do it? how many OIDs do I need to add to the cacti? I use Cisco WS-C2960L-48TS-LL and C9300-48T-4X-E switches, thank you
Mark Elsen
 - You may try to snmpwalk the CISCO-ENVMON-MIB , find the related OID's and then use them in cacti ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
thankyou sir, please can you help me in doing the tutorial? or is there an article that can help me?
basically, these are the two MIBs you need:
1. **CISCO-ENVMON-MIB**: This MIB (Management Information Base) contains temperature-related OIDs for Cisco devices. Look for OIDs under the `ciscoEnvMonTemperatureStatusDescr` and `ciscoEnvMonTemperatureStatusValue` objects. The OID structure typically follows this format:
- `1.3.6.1.4.1.9.9.13.1.3`: This is the base OID for temperature sensors.
- `1.3.6.1.4.1.9.9.13.1.3.1.X`: Replace `X` with the index of the temperature sensor. Each sensor may have a unique index.
2. **ENTITY-SENSOR-MIB**: This MIB defines OIDs for monitoring various sensors, including temperature sensors, on networking devices. Look for OIDs under the `entSensorValue` object. The OID structure typically follows this format:
- `1.3.6.1.2.1.99.1.1.1.4.X`: Replace `X` with the index of the temperature sensor.
halo, thanks sir
After I get the OID, can the OID be used directly to add a new graph template or is there something else I need to do?
