SNMP OID traffic engineering link metric
Jakub Obetko
does Cisco implement some OID to get traffic engineering (te) metric of the link when using MPLS TE? I need actually to write this parameter over SNMP so i need to find an OID through which i get/set this parameter of link. I was looking for it in OSPF-MIB and MPLS-TE-MIB but found nothing yet.
Thanks.
Jakub
Vinod Arya
The MIBs under considerations should be ‘MPLS-TE-STD-MIB’ and ‘MPLS-TE-MIB’.
MPLS TE doesn't have a strong implementation and hence you need to describe what output you're looking in terms of cli equivalent command.
Please check this document which should be helpful :
http://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/te_mib17.html
If you are refferring to output of show mpls traffic-eng tunnels, than you can check :
mplsTunnelResourceMaxRate which shows the maximum rate in bits/second.
Also, you can check 'ifSpeed' gives the tunnel's bandwidth but not the configured value of the TE tunnel.
-Thanks
Vinod
** Encourage Contributors. RATE Them**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
