snmp problem
gerdo1961
Visitor
         I have set up snmp on one of my routers. One of the lines I have entered is
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
The problem is that the router has 4 fastethernet switch ports and I see linkup linkdown messages for all the interfaces however I only want
to see linkup linkdown messages for the dialer2 interface.
Can anyone tell me how to configure it to just send traps for one interface?
Michel Hegeraat
Level 11
Level 11
Depending on the IOS version you can say "no link traps" un the interface configuration.  (Not sure about exact syntax, and it varies among IOS versions I think )
Cheers,
Michel
Hello Michel,
                    Yes that's what I was looking for. I never thought to look under the interface. The correct syntax is
no snmp trap link-status
Thanks.
Yep that's it.
Good luck
Michel
