Hi All,
Does anybody know if there is a way to disable SNMP traps being sent for specific HSRP groups?
In my scenario, I have a number of routers that have multiple HSRP groups defined. Two HSRP groups from each router are in a INIT state because the sub-interfaces that they are on are shutdown. (This is because they are not ready for production yet).
My problem is that my monitoring suite cannot distinguish between HSRP groups on a router - I can't tell it to ignore events for HSRP groups 1 and 2 but not to ignore events for groups 3 and 4. I can only tell it to ignore *all* HSRP events from a specific router. If I do this I may miss genunine events.
Removing the HSRP configuration from the disabled interfaces is not an option, nor is not sending HSRP traps from the routers.
I was hoping to find something like "no snmp trap hsrp" under the sub-if configuration or "no snmp-server enable traps hsrp group X" in global config, but no such luck. The IOS's are 12.4.
Does anyone have any suggestions?
Thanks in advance.
Kevin
