SNMP v2c
ghenaprocop
I want to configure my switch to run snmp v2c, but do not know how to do it(I do not find the exact command).
As I understand, by default the switch will use version 1. I configured as following:
sw(config)#snmp-server community xxxx ro
and in my snmp manager I indicated to use version 2.
The question is: will thw switch run version 2c if my snmp manager run version 2?
My switch is catalyst 2950. IOS version 12.1(19)EA1c
nhabib
Level 9
Level 9
By default, the switch will respond to both snmp v1 and v2c queries simply by configuring:
