SNMP v3 Traps Help
oneirishpollack
Setup my SNMP with the following......
snmp-server view readview internet included
snmp-server view writeview internet included
snmp-server group readonly v3 priv read readview access 20
snmp-server user username readonly v3 auth md5 password priv des56 password
snmp-server group readwrite v3 priv write writeview access 10
snmp-server user username readwrite v3 auth md5 password priv des56 password
This seems to work fine for SNMP polling, but now I am trying to setup traps. I want to encrypt the SNMP data coming back to my management box. I am assuming I need a SNMP manager capable of processing v3 (encrypted) SNMP packets. I am guessing it is something along the lines of.....
snmp-server host 10.1.5.23 traps version 3 priv username
snmp-server enable traps
The problem: I am not receiving traps. I am using Kiwi Syslog to receive them, and I am guessing it is because it looks incompatible with SNMP v3 - correct?
Thanks.
Gaganjeet Chug
Level 4
Level 4
Your configuration is fine. Try to enable the debug for snmp with command "debug snmp packets" with term mon.
Now try to generate the trap and see if device is actually sending the trap to the destination or not.
You can disable the debugging with "no debug snmp packets" and "term no mon"
Gaganjeet
