SNMPSET of BGP attributes
d.fraser
Does anyone know if you can use snmpset to modify BGP attributes such as local Pref and MED??
nhabib
Level 9
Level 9
Not sure, but an easy way to check would be to look at the BGP4-MIB and search for read-write. You would then be able to find all the MIB objects that can be set.
http://ftp.cisco.com/pub/mibs/v2/BGP4-MIB.my
