Is it possible to Increase NVRAM size ?
sajsoft
In one of my routers configuration size is almost 30 K where my NVRAM size is only 32 K .While writing new configuration I am getting an error.
Please help
Saj
spremkumar
Level 9
Level 9
hi
can u revert what kinda router model you are using out there and what kinda error message you are getting over ther ?
also check out whether you got some unecessary files hanging out there and which can be deleted to free up the space..
regds
r.wilcox
I had the same problem and the "service compress-config" global command fixed it.
