10-02-2008 06:31 AM
Is it possible to create a SNMPv3 user which can only be used for traps (SNMP GET requests will not be allowed from the same NMS)?
It seems that creating "notify group" also allows reads:
snmp-server group trapgroup v3 auth notify v1default
show snmp group
groupname: trapgroup security model:v3 auth
readview : v1default writeview: <no writeview specified>
notifyview: v1default
row status: active
Solved! Go to Solution.
10-02-2008 06:33 AM
Sure, just create a bogus read view. For example:
snmp-server view noread iso excluded
snmp-server group notifGroup v3 auth notify v1default read noread
10-02-2008 06:33 AM
10-02-2008 06:35 AM
brilliant!
