SNMPv3 View
oneirishpollack
Level 4
Level 4
Hi all,
Quick question, we are transitioning to SNMPv3. I am trying to understand the the whole view to group to user relationships. What view, when applied to a group, will allow all the users in the group the ability to see all the OIDs (everything "seeable")?
Thanks.
Nael Mohammad
Level 11
Level 11
SNMPv3 by default allows you to poll all the oid till you enable restrictions using cut methods to restrict polling of specific OIDS.  Here is a sample for the configuration.
snmp-server group v3group v3 auth
snmp-server user v3user v3group v3 auth md5 v3pass123
For write access, you add the line below.
snmp-server group v3group v3 auth write v1default
Joe has a great explaination on this thread:
https://supportforums.cisco.com/thread/171669
Nael Mohammad
Level 11
Level 11
Great, so if I understand it correctly, if you don't utilize a specific view, the default is implemented and it allows group members to see the entire OID structure, correct?
After looking at the SNMP tree, is it fair to say that giving a user a view to  iso or internet is pretty much giving them a view to most everything?
oneirishpollack
Level 4
Level 4
Setup my SNMP with the following......
snmp-server view readview internet included
snmp-server view writeview internet included
snmp-server group readonly v3 priv read readview access 20
snmp-server user username readonly v3 auth md5 password priv des56 password
snmp-server group readwrite v3 priv write writeview access 10
snmp-server user username readwrite v3 auth md5 password priv des56 password
This seems to work fine for SNMP polling, but now I am trying to setup traps. I want to encrypt the SNMP data coming back to my management box. I am assuming I need a SNMP manager capable of processing v3 (encrypted) SNMP packets. I am guessing it is something along the lines of.....
snmp-server host 10.1.5.23 traps version 3 priv username
snmp-server enable traps
The problem: I am not receiving traps. I am using Kiwi Syslog to receive them, and I am guessing it is because it looks incompatible with SNMP v3 - correct?
Thanks.
