Software distribution to 805
r-reed
Trying to use RME 4.0 to distribute IOS to 805 router. The issue is flash space. RME says not enough memory. Is there a way around this because I know I can update manually using TFTP. If I can do it manually then RME should be able to do it. I just don't want to have to do 300 routers by hand.
smalkeric
Level 6
Level 6
I think it may be bug, but you can do the same lower than 12.0 version. If it possible try to use TELNET to fetch or download files.
nhabib
Level 9
Level 9
Try editing the memory requirements for the image in the repository
I have set the memory requirements for the image to 2MB for both flash and DRAM. When I create the job it shows 2.88MB flash and 8MB DRAM. This is the error I get when submitting a job:
Warning - SWIM1069:Feature subset of the running image cannot be determined.
Select a different image.
Catastrophic - SWIM1111:The available free space is not enough for upgrading this type of image.
Select a different image or free up some space. Update the inventory and retry the operation.
