02-03-2005 01:22 PM
I installed NAM2(3.3.1 sp3) and have some questions how it works,
1. what components are be monitored without data source setup ? Looks VLAN and port stat only through supervisor module.
2. Do I need setup data source to monitoring above layer 3(ex, appl, host,..) ?
3. How works the report ? Is it continously gathering from Supervisor or data source until 100 days since create the Report?
4. In nGenius(part of LMS) traffic monitor, how can I retrieve the historical data ?
02-03-2005 02:44 PM
1) Only Port Stats info can be obtained without setting up a data source as Port Stats info comes directly from the mini-rmon agent on the switch.
2) Yes
3) Yes
4) RTM only keeps days upto 30 days.
02-03-2005 09:21 PM
getting clear the NAM operation.
For 4), I only can open the real-time GUI for a specific switch port and no option to save or view the historical data such as NAM's.
Q1) How can I save or export the real-time GUI data?
Q2) How can I get 30 days historical data ? Do I need open the real-time GUI for 30 days? or any other way such as NAM's Report feature.
Q3) How can I get 366 days summary data? (I found nGenius doc that 31 days historical and 366 for summary data).
