SSH and TFTP not working on stack after IOS update. Works on non stack
Hey Guys
I'm having a little problem i can't seem to fix.
I've updated our Cisco 2960x switches to version c2960x-universalk9-mz.152-7.E5.bin from c2960x-universalk9-mz.152-2.E7
On our stacked switches, TFTP and SSH isn't working anymore, but it works fine on our single non stacked switches.
Any of you guys have an idear on what happend?
Can't fix it, by restoring the SSH configuration.
7 Replies 7
balaji.bandi
This looks for me config issue - Can you post the config :
Make sure you using right source interfaces to use TFTP and SSH ?
show run ( from the stack it was not working ?)
show ip ssh
BB
That sound a bit weird for me. Cause we have 10 Cisco 2960x, and all the switches have the same IOS upgrade, but only the stacked ones, lost the ability to do ssh and TFTP.
Since it is not working hence this post, can you provide the information I have requested?
show ip ssh
show switch
BB
what responses do you get when you use TFTP and SSH ?
Can you ping the target IP address you use for SSH and TFTP ?
The only thing i get is time out. But i can ping the IP adress of the management interface.
Mark Elsen
 - Was the configuration sufficiently saved before upgrading (on the stacked switches) ?
                >...Can't fix it, by restoring the SSH configuration.
   -  What did you try and or post current configuration.
 M.
Jep, the config was saved correctly before upgrade. Tried to revert the old config, but with no result.
