SSH connection not working on C9300 switch
JBlanchon
I can't connect remotely on the management VLAN on a C9300 switch (IOS version 16.9.5), and I really can't understand because it's the only device on this site with this issue...
When I try to SSH the device, I have a "connection refused by remote host" straight away. I can ping the switch just fine from the outside, I even tested to SSH from a device in the same location and the problem is the same, so this is not a routing issue.
The SSH config is OK, I have created an RSA key, the switch has a domain-name and "ip ssh version 2" is configured.
We are using only local user/passwords to connect, so this is not a RADIUS or TACACS issue as there are none configured. Also, there are no ACLs applied on the VTYs.
As it just wouldn't work with our standard AAA template, I have someone sent on site to login via console, and remove every AAA config and just follow this Cisco doc for the most stripped down local AAA config https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/sec/b_166_sec_9300_cg/configuring_local_authentication_and_authorization.pdf
So now, my aaa config is:
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
And my VTY config has been stripped down as well, now it's only:
line vty 0 4
 transport input all
 transport input all
=> one thing that's bothering me, I tried to configure "login authentication default" in the line config, the command was accepted without any error message, but it doesn't show when I do a show run.
The tech on site didn't have much time, so I couldn't have him run debugs and send me the captures.
Does anyone have any idea about what's going on? This is pretty frustrating, as the issue looks so simple, but I just can't understand why/where something so basic is failing.
Thank you,
Julien
The original post shows that aaa new-model is configured. When this is configured then the behavior is the same as login local. Configuring that command is not needed.
It would be helpful to see the output of show ip ssh on the device. Perhaps also helpful to use debug for ssh.
Rick
6 Replies 6
balaji.bandi
try below command and let us know :  ( i belive you have already crypto and username created)
line vty 0 4
login local
or
line vty 0 15
login local
if this is not working post complete config to understand.
BB
Rick
Hi Richard,
You were definitely on to something with the show ip ssh. I had a tech on site this morning, after a few tests we decided to re-generate the RSA key, and that fixed our issue.
As expected, it was a simple issue, I was just a bit too tired on Friday afternoon to get what was going wrong as fast as I should have.
Thank you!
Julien
Julien
Thanks for the update. Glad that my suggestion pointed you in the right direction. Happy that you got the issue solved. Thanks for sharing the solution with us.
Rick
Hiago Mendes
For anyone with problems to access via SSH, its just use a updated version of Putty and regerate a new RSA key too.
tzakis2003
I do not understand why on standard IOS releases the seem to have caveats that prohibit standard and know command line to work. It is extremely frustrating.  I too had this issue. We have a catalyst routing a point to point and trunking to a 6500 we can ssh to the 6500 no problem the command as expected on both access-class 99 in  (network permited)  transport ssh in  transport out none
works on all our other switches but not this one.  It gets frustrating when you look at ever little detail and spend so much time before going to a forum and seeing a work around posted.  Developers need to get online and make everything standard or at least update software commandline docs to assist customers
