SSH Console slowness in GNS3
Mantas Sti
Hello.
I'm having an issue with SSH console slowness once connected into a network device on GNS3. It generally slow on any router/switch regardless of the configuration to ssh/vty lines.
If using Telnet it's perfectly fine and very responsive but ssh is slow/jittery.
Did anyone come this across?
CCNA Routing and Switching
balaji.bandi
This is looking more of Resource issue or GNS3 installed version on VMWARE Workstation.
what device image is this ? this is more of GNS3 issue related, it is worth to investigate GNS3 forum.
https://gns3.com/community/latest
BB
Hi.
I'm using the below images:
i86bi-linux-l3-adventerprisek9-15.4.1T.bin
i86bi-linux-l3-adventerprisek9-ms.155-2.T.bin
But even the L2 images have the same issue.
Thanks.
is the cpu on the devices maxed out when you do a show proc cpu sorted ,fact you have multiple images would suggest resource general issue rather than SSH issue itself ,ssh requires alot more than telnet as its using crypto
