ssh from prime infrastructure
steve switzer
i am having problems getting snmp to to connect to cisco devices.
Now i know you can ssh from the lifecycle view using the 360 viewr whatever its called
But i want to try and ssh to unknown devices and see why i am getting unreachable
when my lms and cacti can reach these devices just fine
If I could try this then i could establish if it is prime or something funny on the network
Many thanks
Steve
AFROJ AHMAD
Hi Steve,
I don't think we have the feature to SSH to a device from 360 Degree view.
Can you share the same screen shot ?
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I'm facing the same issue, my PI 2.1 can't discover any devices outside the local server VLAN(even can't manully add the devices) , I can ssh to the network devices within the same PI VLAN but I couldn't ssh outside the PI VLAN, it is not a routing or FW issue
