SSL Certificate on Prime 3.5
ritchieb
I am trying to install a SSL certifcate and key on Prime v3.5 and running into an issue.
On a fresh install of version 3.0 I am able to successfully run the following;
PRIMESVR/admin#copy ftp://#.#.#.#/mykey.key disk:defaultRepo
PRIMESVR/admin#copy ftp://#.#.#.#/mycert.cer disk:defaultRepo
PRIMESVR/admin#!
PRIMESVR/admin#ncs key importkey mykey.key mycert.cer repository defaultRepo
PRIMESVR/admin#ncs stop
PRIMESVR/admin#ncs start
Once completed the certificate is installed and when I browse to the server the certificate is correct and trusted.
On a fresh install of Prime version 3.5 I run the same commands as above and get the error below;
PRIMESVR/admin#!
PRIMESVR/admin#unable to load certificate
140711382058672:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:708:Expecting: TRUSTED CERTIFICATE
ERROR: Failed to import key certificate. Public key in certificate does not match with private key
ERROR: ncs key importkey command failed. rval:256
PRIMESVR/admin#
I've searched and tried many things but cant get to the fix, can anyone assist?
ritchieb
Took a step back and some more reading and figured out that the server wanted the cert in a Base 64 encoded format, went back to our internal CA and re-issued choosing the Base 64 version and voila!
PRIMESVR/admin# ncs key importkey mykey.key mycert-base64.cer repository defaultRepo
Imported server key. Changes will take affect on the next server restart
PRIMESVR/admin#
ritchieb
PRIMESVR/admin#
