Strange DHCP Behavior
tourless27
Hi Folks,
i have a strange problem whereby my dchp scope exclusions do not seem to be taking effect... as you can see I have defined my excluded address ranges but the pools show 254 addresses.  Why?
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.16.1 192.168.16.100
ip dhcp excluded-address 192.168.17.1 192.168.17.10
ip dhcp pool ITS
   network 192.168.16.0 255.255.255.0
--More--            option 150 ip 192.168.16.1
   default-router 192.168.16.1
   dns-server 192.168.1.25 192.168.1.2 64.115.0.9 64.115.0.10
ip dhcp pool ITS_Phones
   network 192.168.17.0 255.255.255.0
   default-router 192.168.17.1
Pool ITS :
Utilization mark (high/low)    : 100 / 0
Subnet size (first/next)       : 0 / 0
 Total addresses                : 254
Leased addresses               : 28
Pending event                  : none
1 subnet is currently in the pool :
Current index        IP address range                    Leased addresses
192.168.16.185       192.168.16.1     - 192.168.16.254    28
Pool ITS_Phones :
Leased addresses               : 12
192.168.17.21        192.168.17.1     - 192.168.17.254    12
Thanks in advance.
Milos Megis
Level 3
Level 3
try to type command "show ip dhcp binding" to see which addresses are assigned to clients.
You will see that excluded addresses are not assigned.
Milos Megis
Level 3
Level 3
