Streaming telemetry power supply
Idodon2021
Hello everyone!
I’m trying to monitor power supplies on Cisco c9500-24y4c with streaming telemetry.
the xpath I am trying to use is
/platform-ios-xe-oper:components/component/platform-properties/platform-property
I can’t seem to find the data I need which is if my power supply is connected or not.
if anyone knows if there is something I need to do or a different xpath I need to use for power supplies I would love to hear.
balaji.bandi
What is the IOS XE code running? Is this only data that is not displaying? How about other data?
check the configuration guide for reference if you missed any config :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/175/b_175_programmability_cg/m_175_prog_ietf_telemetry.html
BB
