Subinterface SNMP issue
Hello All
I have upgraded ASR-1002x ios version from asr1002x-universalk9.03.16.09.S.155-3.S9-ext.SPA.bin to asr1002x-universalk9.17.033.SPA.bin .
No problem but very strange thing occured. I have subinterfaces in configuration  like Gi 0/0/2.501 .... After IOS-XE  upgrade, my network management tools like Solarwinds and Cacti could not able to create subinterface bandwidth values on graph.
İ can see subinterface names and graphs but can not able o write its bandwidht on graph.
yajimene
Looking at the version you upgraded to, this could be related to:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy25845
As stated on the bug, the problem is not seen on 17.3.2
- Yaros
8 Replies 8
Mark Elsen
 - Could you snmpwalk the device(interfaces)  again and or look for the intended oid's -> sometimes the oid's can get changed (slightly). You may then need to adapt your snmp manager settings in order  to use the correct oid's again for the intended sub-interfaces.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
Do you have traffic on that interface, can you post show interface gi 0/0/2.501
on solarwinds, go to device, list resources or option poll now again check.
is this only issue with sub-interface- rest of the interface able to produce what you looking ?
BB
yes i have traffic on that subinterface
this is only issue about subinterface . My regular Layer-3  interface graph is ok .
i have this output ;
XXX#sh snmp mib ifmib traps
ifDescr ifindex TrapStatus
GigabitEthernet0/0/2.501 24 disabled
Loopback777 19 enabled
Tunnel27 21 enabled
GigabitEthernet0/0/3.3968 37 disabled
GigabitEthernet0/0/4 5 enabled
Loopback66 18 enabled
GigabitEthernet0/0/3.3220 31 disabled
Tunnel27 21 enabled
i have seen this before, but in solarwinds i can see the traffic on sub interface.
example as below :
BB
yajimene
- Yaros
Hello Guys Thanks for all answers
After downgrading to version asr1002x-universalk9.16.12.05.SPA.bin ( Gibraltar Version ) traffic rates created.on graphs  This was a bug.
