Subinterfaces and VLANs together on the same device
encap
I have a non-vlan capable Linux PC with a sub-interface 192.168.1.x/24 and 192.168.2.x/24 connected to an IR1821.
Linux PC connected to Port 0/1. I have devices on Port 0/2 192.168.1.x/24 (vlan 10) and Port 0/3 192.168.2.x/24 (vlan 20)
The goal is to maintain vlan isolation (these are hard coded and I can't change them) while allowing the linux PC to communicate to each device on each vlan.
Can I configure Port 0/1.10 with dot1q 10 IP 192.168.1.254/24
Port 0/1.20 with dot1q 20 192.168.2.254/24
And standard vlan configured access ports 0/2 (vlan 10) and 0/3 (vlan 20)
No routing in between vlans is needed at this time.
I can not add a second network port to the PC.
Only l3 port can config with subinterface' l2 port (config with vlan) can not config with subinterface
MHM
encap
Can you suggest a path forward so that my linux device with a single physical port and one virtual port on two separate IP addresses can communicate with both vlan 10 and 20 over the single router I have?  What am I missing?
Thanks!
