Sup boot sequence statement
kar.bibhu
Community Member
In my 6509 switch IOS stored in Sup-bootflash:. I can check it by giving command dir sup-bootflash. But in config there is no boot sequence command. Can some one pls advice which command should i enter to reflect the same in running config?
Leo Laohoo
In enable mode, try
sh bootvar
Please rate if the post is helpful and/or applicable. Thanks.
