SVI and Static MAC
meisemann7
Thought I would put this out there as I can't find an answer to this question.  I will purposely not include all the history as I am asking a specific question.  I am trying to add a mac-address command to a new L3 switch's SVI interfaces so the MAC is manually established in the SVI.  Like
int vlan x
  mac-address AAAA.BBBB.CCCC.DDDD
These SVIs are in an 'admin down' state and when I put in the 'mac-address AAAA.BBBB.CCCC.DDDD' in the 'interface VLAN x' , communication stops for that VLAN even though the SVI is shutdown.  Do you know why?  If it helps this is a Cisco Catalyst 3650 L3 switch.  I am purposely trying to change the MACs in the SVIs to stage them for a switch migration.
clarification:  Communication is fine for the VLAN x if I don't manually change the mac-address with the command.
Matt
closing this for now, not sure why VLAN communication stops if the interface is down though.
Matt
balaji.bandi
Not sure we able to understand your question correctly ?
what communication stops ?
read some reference  here :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/41263-catmac-41263.html
BB
Matt
