02-23-2019 05:00 AM
I having a problem in my configuration in cisco switch 3650 since when I run the command
Switchport trunk encapsulation dot1q
it will respond as % Invalid input detected at '^' marker.
What is correct command for this?
Thank you in advance.
Solved! Go to Solution.
02-23-2019 05:18 AM
Hi @blitzkirze ,
Check this answer of the Community:
https://community.cisco.com/t5/switching/cisco-3650-and-802-1q-encapsulation/td-p/2779282
02-23-2019 05:18 AM
Hi @blitzkirze ,
02-23-2019 05:33 AM
02-23-2019 05:41 AM
02-23-2019 06:12 AM
Hi @blitzkirze ,
Check if you can enter the ip routing command. That command enables routing on the switch, so it would only be necessary SVI to configure them as your vlan's gateways.
