Cisco 3650 and 802.1q encapsulation
sanjaynadarajah
I have a Cisco 3650 running software version 03.06.03E.
I noticed that I cannot set the encapsulation to dot1q even though I have configured the port as a trunk.
Current configuration : 248 bytes
interface GigabitEthernet1/0/1
 description Switchport Trunk Configuration
 switchport access vlan 999
 switchport trunk native vlan 998
 switchport trunk allowed vlan 998,999
 switchport mode trunk
 switchport nonegotiate
 load-interval 30
end
When I look at the interface configuration, it says its a trunk port.
switch#sh interfaces g1/0/1 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/1     on               802.1q         other         998
Port        Vlans allowed on trunk
Gi1/0/1     none
Port        Vlans allowed and active in management domain
Gi1/0/1     none
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/1     none
switch#
So I believe that if a port is made a trunk port, the encapsulation mode by default would be a 802.1q. Would that be correct ?
Thank you.
Cheers,
  SN
johnd2310
Level 8
Level 8
Yes,the switch only support 802.1q.You cannot set the encapsulation.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3e/vlan/configuration_guide/b_vlan_3e_3650_cg/b_vlan_3se_3650_cg_chapter_0100.html
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
