Switch Catalyst 3650
blitzkirze
I having a problem in my configuration in cisco switch 3650 since when I run the command
Switchport trunk encapsulation dot1q
it will respond as % Invalid input detected at '^' marker.
What is correct command for this?
Thank you in advance.
luis_cordova
Thanks for your reply.
I have a question again, can I do an inter v-lan in Cisco 3650 ?
Thank you,
Hi @blitzkirze ,
Check if you can enter the ip routing command. That command enables routing on the switch, so it would only be necessary SVI to configure them as your vlan's gateways.
