Switch port configuration in that way that VM were reachable
How to configure Gi0/1 and Gi0/2 switch port interfaces so that any VM is reachable/pingable from router R1 ?
Note: VLAN 50 has been reserved for special purposes. It should not be assigned to any of interfaces and/or links.
balaji.bandi
Create a VLAN in Switch VLAN 10 20 30 40
Interface gi 0/2
switchport
switchport mode trunk
switchport trunk allowed vlan 10,20,30,40
Interface gi 0/1
switchport
what you mean untagged vlan 40 in VM side ? you like to make a native ?
Same way you need to configure vswitch.
BB
as far as I recall, the native Vlan does not have to be explicitly allowed on the trunk. So your configs would be:
interface GigabitEthernet0/1
switchport trunk encapsulation dot1q <-- this might or might not be required
switchport trunk native vlan 40
interface GigabitEthernet0/2
In the output you posted, Vlan 40 is tagged. If you really want this Vlan to be untagged, you need to configure the subinterface on the router with the 'native' keyword:
interface GigabitEthernet0/0/0/40
encapsulation dot1q 40 native
