Switch reset
pavkad
Frequent Visitor
Frequent Visitor
I have such a special question, I own a swicht SRW248G4 so this is the first manage swicht from Linksys together with CISCO. Since I used to use it, I wanted to use it now, however I don't remember the IP anymore, putty and hyperterminal won't start. There is no reset button, but I do remember that somehow the LAN ports got connected and a reset to default occurred. Please does anyone remember the procedure of linking those LAN ports?
Thank you
9 Replies 9
Mark Elsen
  - FYI : http://resetrouter.info/router/Linksys/SRW248G4
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
check the manual reset :
https://www.linksys.com/us/support-article?articleNum=139032#manual
BB
This switch does not have a reset button. That's why I posted which one it is.
as per the model that is the document see, i have not hands on that device, we go with the information, can you post the image of the device ?
BB
Here, I have a photo of it in operation. The thing is, I can't get past the putty or the hyperterminal. I don't remember the IP I entered to configure it. I read somewhere once that it can be reset by connecting RJ45 to two ports that you connect with a LAN cable and let it go, this is supposed to reset it. But I don't remember where that was. I couldn't find a reset on the motherboard either.
    - Reset button could be at the back and or post picture of back-side too.
 M.
There is no reset button on this device either on the back or on the side. Reset should be done via cross RJ45 but I don't know in what order the LAN ports are connected. It's actually the only switch that doesn't have a reset button
Dont have experience with the Linksys models
did the device has console  ?
https://oitibs.com/reset-linksys-srw-series-switches/
BB
