Synchronize archive
dominoforever
Hey,
I would like to backup the config of all devices but I have an error whan I launch the Sync Archive.
See the error below:
The following is the status of your Sync Archive job:
Job ID         : 1637
Status         : Job Failed(1)
Description   : test sync
Details       : http://ciscolms.domain.local:1741/rme/DcmaJobDetails.do?jobid=1637
Start Date and Time : Mon Aug 08 11:02:14 CEST 2011
End Date and Time   : Mon Aug 08 11:03:23 CEST 2011
RME Server Name/IP : ciscolms.domain.local
Execution Summary
Pending         : 0
NotAttempted     : 0
Successful       : 0
Failed           : 1
Partial Success : 0
I don't know if I forgot something, could you please help me?
Kind regards,
Sébastien
45 Replies 45
Hi Afroj,
When I had problems at the begining, I saw on the forum that somebody had the same problems. So he modified the file TacasPrompts.ini like that :
[TELNET]
USERNAME_PROMPT=Username:,username:,login:
PASSWORD_PROMPT=Password:,password:,passwd:
I modified my file like the same way.
Thanks.
Hi Seb,
you are right that what we need to configure in your case :
[TELNET]
USERNAME_PROMPT=login:
I hope the jobs are running file after this..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
I always have the same error with job failed(1). What can we check?
Thanks.
Hi seb,
Enable the debugging for Archive Management and device Management under  RME >admin>system prefreneces >Application log level settings
--Ran a Sync Archive and CDA job for the problematic device
--Once the job is finished send me the cda.log ,EssentialDM_server.log and dcmaservice.log and job folders
  • Also Try to connect the device via Telnet from the LMS server and update me, whether able to TELNET to the device from the LMS server
Afroj
è schedule a Sync Archive and CDA job for the problematic device and trigger packet capture. And get us the following:
·         Packet capture for both Sync Archive and CDA Job
·         Screenshot of the device login prompts (When Connected via TELNET)
·         Try to connect the device via Telnet from the LMS server and update us, whether able to TELNET to the device from the LMS server
Hi Afroj,
See the logs files attached.
If I try to connect to one of my devices from my LMS server it works fine.
Thanks.
Hi Afroj,
Did you have a look to my log files?
Thanks.
Afroj,
Did you check my files? Could you please help me?
Thanks.
Hi seb,
Did you ran the device credentilas verification job for this device :192.168.254.111
what is the status of the CDA job.?
If  CDA job still says No Value to test then first check the device  credentilas fot this device by Exporting in a text file ( Common service  >device mgmt ) and verify that the credentials are correct..
If the Exported credentilas are correct then send me the TACACSPROMPTS.ini file..
Afroj
This is the result of the CDA job.
Could you please tell me where I have to go to export the device credentials. You wrote common service -> device mgmt, how I have to go there?
Thanks.
Hi Seb,
Kindly check the attached screen shot..
Afroj
Thank you Afroj,  but I have LMS 4.0 I haven't the same menu...
Hi ,
My Bad.. I forgot ..
In lms 4.0 :
Go to :  Inventory > Device Administration > Add / Import / Manage Devices
Afroj
I found it Afroj!
This is the file generated by the export.
            192.168.254.111
            192.168.254.111
            192.168.254.111
            1.3.6.1.4.1.9.1.1208
            Tennis
There is no credentials, it is normal?
My TacacsPrompts.ini file :
[TELNET]
Thanks.
Hi Seb,
It means you have not defined any TELNET\SSH credentilas.. Please add the Right credentilas and I hope that will take care of the issue..
Afroj
Hi Afroj,
I edited the credentials for all my devices in the Add / Import / Manage Devices but the synchronization doesn't work for all of them. It worked for 3 devices, I have an error for others.
Have you an idea?
Thanks.
