Syslog in LMS4.2.2
nawas
Level 4
Level 4
I have about 500 devices in my LMS4.2.2 and they are all managed by Hostname/DNS name. when I go look at the raw syslog file (tail -f syslog_info) I see most of the devices (more than half) sending syslog  mesaages by their IP address instead Thus do not show up in my 24-hour syslog report. my LMS is on soft appliance. Any thoughts?
Michel Hegeraat
Level 7
Level 7
Perhaps use the logging source interface command to make the device send syslog with the management interface
Cheers,
Michel
There is only one interface in these switches (layer 2 access switches).
Then you DNS works from name to IP but not from IP to name.
Make sure reverse lookup is configured properly.
You can also create a local hostfile on the server
Cheers,
Michel
Not a DNS issue. DNS works and reverse works too. If it didn't work, RME would never manage devices by its DNS names. What I see that device is managed by its DNS (lets says 1-c-4507-22) name but the syslog (syslog_info) file seeing syslog coming from the IP address (10.1.1.22). I know it is wierd,  I can reacll back in RME3.x days there were similar issues with syslog and I have a feeling that  the bug has returned in LMS4.2.2. I tried delete/add device with no help.
