Syslog Problem
nawas
Level 8
Level 8
New install on Sol9, RME4.0 with Dec05 update. I can't get syslog to work, I get nothing under var/log/syslog_info. Logging is enabled for this server. config archive works that tells that devices are managed, I can do netconfig job but no syslog. syslgd is also running
>> ps -ef | grep syslogd
root 210 1 0 Mar 06 ? 0:40 /usr/sbin/syslogd -t
muhamns 2319 2310 0 15:51:40 pts/1 0:00 grep syslogd
muhamns@sip10a>> netstat -a -n | grep 514
mfreeman451
Level 3
Level 3
Can you show me your /etc/syslogd.conf please?
cat /etc/syslogd.conf
I don't have access to an RME box at the moment to show you mine but if you don't have a line dumping I think local7 to syslog_info that is your problem. If you do, try stopping and starting the syslogd daemon. I believe /etc/init.d/syslogd stop
/etc/init.d/syslogd start
does the trick
Hi Thanks.
Yes I have the line in syslog.conf file and also have tried stop/start syslog and reboot thebox but that didn't help either.
#END CSCOmd DO NOT EDIT BEFORE THIS LINE 1
# Added for Cisco Syslog Analyzer (begin)
local7.info /var/log/syslog_info
# Added for Cisco Syslog Analyzer (end)
nhabib
Level 11
Level 11
Check if the messages are making it to the server.
Pick an IOS device (let's say its ip address is 10.10.10.10) and as root on the server issue the command:
snoop -s 1518 -o /tmp/trace 10.10.10.10
On the device, issue the commands:
conf t
exit
This should send a syslog message to the server.
CTRL+C out of the snoop and you may use Ethereal to open the /tmp/trace file and confirm whether the syslog message made it or not
You can also generate syslog events with the solaris cli tool "logger"
