tcl and aggregated ports
andrewboey
When I do an SNMP poll of some ports on a switch, I get these results:
(tcl)#snmp_getbulk public 0 9 dot3adAggPortActorOperState.10100
{<obj oid='dot3adAggPortActorOperState.10101' val=''/>}
{<obj oid='dot3adAggPortActorOperState.10102' val='<'/>}
{<obj oid='dot3adAggPortActorOperState.10103' val=''/>}
{<obj oid='dot3adAggPortActorOperState.10104' val='<'/>}
{<obj oid='dot3adAggPortActorOperState.10105' val=''/>}
{<obj oid='dot3adAggPortActorOperState.10106' val='<'/>}
{<obj oid='dot3adAggPortActorOperState.10107' val=''/>}
{<obj oid='dot3adAggPortActorOperState.10108' val='<'/>}
{<obj oid='dot3adAggPortActorOperState.10109' val=''/>}
When I do it externally i get different values:
.1.2.840.10006.300.43.1.2.1.1.20.10101 = ""
.1.2.840.10006.300.43.1.2.1.1.20.10102 = Hex-STRING: BC
.1.2.840.10006.300.43.1.2.1.1.20.10103 = ""
.1.2.840.10006.300.43.1.2.1.1.20.10104 = Hex-STRING: BC
.1.2.840.10006.300.43.1.2.1.1.20.10105 = ""
.1.2.840.10006.300.43.1.2.1.1.20.10106 = Hex-STRING: BC
.1.2.840.10006.300.43.1.2.1.1.20.10107 = ""
.1.2.840.10006.300.43.1.2.1.1.20.10108 = Hex-STRING: BC
.1.2.840.10006.300.43.1.2.1.1.20.10109 = ""
Any ideas why?
Some of the switches I want to do this on don't have eem support which is why I want to do this in TCL.
andrewboey
So I figured this out and it seems so obvious now.
For whatever reason Cisco is dumping the hex-STRING and instead puts a binary value in it's place. You cannot use string operators to match on the binary values. So all of the things I was trying to do with what I assumed to be a string was failing miserably. I have to convert from binary value of '<' to hex using binary scan. Now I can do all the string matches I want on the new variable created by binary scan.
Hope this helps someone in the future.
