TCL script, interface bitrate
Krasnoperov
Hi, I need a script which will track all interface on device (catalyst or router) and if a bitrate output or input higher then threshold, it will send a message on e-mail with list ofp interfaces and bitrate on it.
I think this is hard problem, but may be somebody have similar script
thanks
13 Replies 13
Joe Clarke
This script should do what you want.  It is an Embedded Event Manager Tcl policy that uses the timer event detector.  You will need to configure some EEM environment variables before you can register the policy.
bitrate_interval : Time (in seconds) between executions of the script
bitrate_rising_threshold : Upper threshold for bits per second before an email will be sent
bitrate_falling_threshold : Lower threshold for bits per second before an interface will be seen in an email again
_email_server : IP address of the SMTP server
_email_from : Email address of the sender
_email_to : Email address of the recipient
_email_cc : (optional) email address(es) of additional recipients
For example, in config t mode:
event manager environment bitrate_interval 60
event manager environment bitrate_rising_threshold 1000000
event manager environment bitrate_falling_threshold 1000
event manager environment _email_server 10.1.1.1
event manager environment _email_from user@company.com
event manager environment _email_to user@company.com
Copy this script to a directory on flash called "policies", then register it with:
event manager directory user policy flash:/policies
event manager policy tm_check_bitrate.tcl
Thanks a lot for your answer, but I have some problem with script
first when I do this
r1(config)#event manager policy tm_check_bitrate.tcl
Compile check failed:missing close-bracket
    while compiling
"set mail_msg"
r1(config)#
Tcl policy execute failed: missing close-bracketcouldn't compile policy file to bytecode: Unknown error 0
Sorry, I'm not coder but I decide to fix bracket here, might be I'm wrong
set mail_msg [uplevel #0 [list [subst -nobackslashes -nocommands $mail_pre]]]
if [catch {smtp_send_email $mail_msg} result] {
    error $result $errorInfo
After that it shows this
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: invalid command name "run_ci"
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:     while executing
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: "run_ci [list "show interface | inc ^\[A-Z]| rate""
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:     invoked from within
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: "$slave eval $Contents"
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (procedure "eval_script" line 7)
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: "eval_script slave $scriptname"
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: "if {$security_level == 1} {       #untrusted script
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp create -safe slave
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdout slave
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stderr slave..."
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Feb 24 16:48:43: %HA_EM-6-LOG: tm_check_bitrate.tcl: Tcl policy execute failed: invalid command name "run_ci"
Where I'm wrong ?
Try this version.
I have same kind of message "Tcl policy execute failed: invalid command name "run_ci""
RouterRouter#fh_fd_timer_event_expire: re=0x64C09C34
Mar  2 15:42:51: fd_pulse_hndlr: received a pulse from /dev/fm/fd_timerfh_fd_timer_info_publish: pe = 0x63B8B1F4
Mar  2 15:42:51: fh_msg_send_to_fd: receive a reply msg, minor: 5
Mar  2 15:42:51: fd_pulse_hndlr: received FH_MSG_EVENT_PUBLISHfh_schedule_policy: prev_epc=0x00000000; epc=0x64BFFB38
Mar  2 15:42:51: fh_schedule_policy: policyname=system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tclspawn script system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tclEEM policy system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tcl has been scheduled to run
Mar  2 15:42:51: fh_spawn: -FMRUN -FMSAFE system:/lib/tcl/base.tcl system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tcl
Mar  2 15:42:51: fh_tcl_spawn: argc=5, argstr=-FMRUN, stdin=null:/tm_check_bitrate.tcl, stdout=syslog:/info/noscan/tm_check_bitrate.tcl,stderr=syslog:/err/noscan/tm_check_bitrate.tcl, priority=3pid for spawned process is 57
Mar  2 15:42:51: fh_tcl_esi_open: fd=1
Mar  2 15:42:51: fh_tcl_esi_open: fd=2
Mar  2 15:42:51: fh_tcl_get_mode: mode = 1, StartupScript = system:/lib/tcl/base.tcl, RealScript = system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tcl
Mar  2 15:42:51: fh_io_msg: received FH_MSG_API_INIT; jobid=17179, processid=57, client=17169, job name=EEM TCL Proc
Mar  2 15:42:51: fh_register_evreg_cmds: tctx=64DE72EC, dummy=1
Mar  2 15:42:51: fh_tcl_compile_policy: evaluating policy: startup_scriptname=system:/lib/tcl/base.tcl, real_scriptname=system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tcl
Mar  2 15:42:51: fh_tcl_slave_interp_init: interp=6477D674, tctx=64DE72EC, fh_mode=1, real=system:/lib/tcl/eem_scripts_registered/tm_check_bitrate.tcl, curr=
Mar  2 15:42:51: [fh_dummy_cmd]
Mar  2 15:42:52: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:42:52: fh_fd_data_syslog: num_matches = 0received SIGCHLD pulse from child death pid=57received pulse from child death code=1; epc=0x64BFFB38EEM policy tm_check_bitrate.tcl has ended with normal exit status of 0x0fh_schedule_policy: prev_epc=0x64BFFB38; epc=0x00000000
Mar  2 15:42:52: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 17169 pclient 17169
Mar  2 15:42:52: fh_io_msg: received FH_MSG_API_CLOSE client=17169
Mar  2 15:42:52: fh_tcl_esi_close: fd=1
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: invalid command name "run_ci"
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:     while executing
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: "run_ci [list "show interface | inc ^\[A-Z]| rate""
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:     invoked from within
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: "$slave eval $Contents"
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (procedure "eval_script" line 7)
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: "eval_script slave $scriptname"
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: "if {$security_level == 1} {       #untrusted script
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp create -safe slave
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdout slave
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stderr slave..."
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Mar  2 15:42:52: %HA_EM-6-LOG: tm_check_bitrate.tcl: Tcl policy execute failed: invalid command name "run_ci"
Router#
Mar  2 15:42:52: fh_tcl_esi_close: fd=2
Mar  2 15:42:52: fh_tcl_assoc_data_delproc: freeing tctx=64DE72EC
Router#
Mar  2 15:42:57: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.46(2041) -> 94.245.71.209(80), 1 packet
Router#
Mar  2 15:42:57: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:42:57: fh_fd_data_syslog: num_matches = 0
Router#cron_tick: num_matches 0
Router#
Mar  2 15:43:02: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.46(2042) -> 94.245.71.213(80), 1 packet
Router#
Mar  2 15:43:02: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:02: fh_fd_data_syslog: num_matches = 0
Mar  2 15:43:03: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.19(3842) -> 184.168.222.198(80), 1 packet
Router#
Mar  2 15:43:03: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:03: fh_fd_data_syslog: num_matches = 0
Router#
Mar  2 15:43:07: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.46(2043) -> 94.245.71.209(80), 1 packet
Router#
Mar  2 15:43:07: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:07: fh_fd_data_syslog: num_matches = 0
Router#
Mar  2 15:43:10: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.19(3843) -> 75.101.227.242(80), 1 packet
Router#
Mar  2 15:43:10: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:10: fh_fd_data_syslog: num_matches = 0
Router#
Mar  2 15:43:12: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.46(2044) -> 94.245.71.213(80), 1 packet
Router#
Mar  2 15:43:12: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:12: fh_fd_data_syslog: num_matches = 0
Router#term no
Mar  2 15:43:17: %SEC-6-IPACCESSLOGP: list 102 denied tcp 192.168.107.46(2045) -> 94.245.71.209(80), 1 packet
Router#term no
Mar  2 15:43:17: fh_fd_syslog_event_match: num_matches = 0
Mar  2 15:43:17: fh_fd_data_syslog: num_matches = 0
It looks like you have not re-registered the script after copying the modified version.  Be sure you do:
no event manager policy tm_check_bitrate.tcl
Did exactly what you said, now this kind of error occurs:
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     while executing
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "if { $iidx != -1 && $paramarr(input) <= $bitrate_falling_threshold } {
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:    set ifilst [lreplace $ifilst $iidx $iidx]
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     } elseif { $iidx == -1 && $param..."
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     ("foreach" body line 5)
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     invoked from within
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "foreach param [array names ifarr] {
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     array set paramarr $ifarr($param)
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     set iidx [lsearch -exact $ifilst $param]
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     set oidx [lsearch -exact $i..."
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "$slave eval $Contents"
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (procedure "eval_script" line 7)
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "eval_script slave $scriptname"
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "if {$security_level == 1} {       #untrusted script
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp create -safe slave
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdin slave
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdout slave
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: ..."
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Mar  5 14:33:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: Tcl policy execute failed: can't read "paramarr(input)": no such element in array
Mar  5 14:33:18: fh_tcl_esi_close: fd=2
Mar  5 14:33:18: fh_tcl_assoc_data_delproc: freeing tctx=8464D2D8received SIGCHLD pulse from child death pid=172received pulse from child death code=2; epc=0x847D25B4EEM policy tm_check_bitrate.tcl has ended with abnormal exit status of 0x1fh_schedule_policy: prev_epc=0x847D25B4; epc=0x00000000mon
Post the output of the command:
show interface | inc ^[A-Z]| rate
It looks like your output format may differ from my test device.
FastEthernet0/0 is up, line protocol is up
  5 minute input rate 1615000 bits/sec, 541 packets/sec
  5 minute output rate 1609000 bits/sec, 543 packets/sec
FastEthernet0/0.2 is up, line protocol is up
FastEthernet0/0.3 is up, line protocol is up
FastEthernet0/0.168 is deleted, line protocol is down
NVI0 is up, line protocol is up
Ah, you have some sub-interfaces.  Try this version.
Now it's just do not want to register
Sorry, but after second try it's regestred !  but some errors still exist
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     while executing
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "{Mailservername: 192.168.100.41
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: From: ask@xxx.ru
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: To: ask@xxx.ru
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: Cc:
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: Subject: Interface Utilization Alert
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: The following interfaces have high in..."
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     ("uplevel" body line 1)
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     invoked from within
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "uplevel #0 [list [subst -nobackslashes -nocommands $mail_pre]"
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "$slave eval $Contents"
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (procedure "eval_script" line 7)
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "eval_script slave $scriptname"
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: "if {$security_level == 1} {       #untrusted script
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp create -safe slave
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdin slave
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:      interp share {} stdout slave
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: ..."
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl:     (file "system:/lib/tcl/base.tcl" line 50)
Mar  9 15:57:18: %HA_EM-6-LOG: tm_check_bitrate.tcl: Tcl policy execute failed: invalid command name "Mailservername: 192.168.100.41
Try this version.
it's working, message are coming to my e-mail
but there is some issue in message body
its coming like this (do not display interfaces which are above the threshold):
To: ask@xxx.ru
Cc:
The following interfaces have high input bitrate (above 1000000 :
The following interfaces have high output bitrate (above 1000000 :
Sorry, I forgot to exit if there were no interfaces above the threshold.  This version should suppress those emails.
