TCL Script not working after upgrade to sr4300-universalk9.16.09.06.SPA.bin
1damianjones
We have a ISR4331 that we use as a voice gateway. Currently it is on version isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin and it works without any problems. After the upgrade it doesn't even initialize the call I ran a kron debug and found   Can someone decipher this
with isr4300-universalk9.16.09.06.SPA.bin:
000178: Dec 28 12:23:38.577: %SYS-5-CONFIG_I: Configured from console by onyx on vty0 (10.1.1.117)
000179: Dec 28 06:25:00.001: Major 1, Minor 0 000180: Dec 28 06:25:00.001: Timer Event ShiftChange10
000181: Dec 28 06:25:00.001: Kron delay for next ShiftChange10 86400000
000182: Dec 28 06:25:00.002: Call parse_cmd 'csim start 7777'
000183: Dec 28 06:25:00.004: Kron CLI return 2 '
000184: Dec 28 06:25:00.004: Major 4, Minor 7
000185: Dec 28 06:25:00.004: Respond to end of CLI Process
000186: Dec 28 06:25:00.005: Call parse_cmd 'csim start 7777'
000187: Dec 28 06:25:00.007: Kron CLI return 2 '
000188: Dec 28 06:25:00.007: Major 4, Minor 7
000189: Dec 28 06:25:00.007: Respond to end of CLI Process
on the box :
application service paging flash:paging_89.tcl
param prompt-1 flash: 500hztone.au
kron occurrence ShiftChange1 at 6:00 recurring
policy-list ShiftChange
kron occurrence ShiftChange2 at 9:00 recurring
kron policy-list ShiftChange
cli csim start 7777
cli csim start 7777 !
balaji.bandi
Have you read the release notes before upgrading?  there are some bug in related to IVR and Voice
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-16-9/isr4k-rel-notes-xe-16-9.html
Try Uplift to another new version and see if that fixes. or raise a TAC Case if you have a support contract.
BB
Leo Laohoo
Could be CSCvp62388.
